Jeep has unveiled its new fifth-generation Grand Cherokee. And it’s launched as a three-row, seven-seat model called the Grand Cherokee L, ahead of the standard two-row version and a new, electrified model named ‘4xe’ later this year.
Arriving with a new design that takes inspiration from the original Wagoneer, exterior changes include a longer hood and cab, a forward-tipped seven-slat grille, slim LED headlights front and rear, plus optional 21-inch alloy wheels. If the pictures are anything to go by, we think it looks rather good, though this seven-seat version isn’t set to make it to Europe.
Based on a new aluminum architecture, a series of revisions including a front axle bolted directly to the engine, plus new active engine mounts—which soften and stiffen according to the engine speed—are intended to improve on-road refinement.
Meanwhile, to improve off-road ability, the new model will be available with three 4x4 systems dubbed ‘Quadra-Trac,’ plus optional air suspension which can raise the ride height by up to 60mm when you need more ground clearance, or lower it by 46mm in Park Mode for easier access.
Front axle disconnect is also new. If the vehicle senses that road conditions do not require all-wheel-drive, the front axle disconnects automatically, with the model reverting to two-wheel-drive to improve fuel economy. Four-wheel drive automatically re-engages when the vehicle senses it’s needed.
In the US, the model will be offered with a 3.6-liter petrol V6 as standard or the flagship 5.7-litre Hemi V8. In Europe, it will likely be sold with a range of smaller-capacity motors, plus a 4xe plug-in hybrid from launch.
Improvements also extend to the cabin, which is now available in four-trim levels: Laredo, Limited, Overland, and Summit. The model also features new digital displays, including a 10-inch infotainment touchscreen, while new 10-inch digital gauges can also be configured to show nearly two dozen different displays.
Tempted, Internet?
